HAL.PoE.HwFastCfgMisMatch
Description
The PoE running configurations queried from hardware at boot time do not match the configurations loaded from the configuration
Remedy
This error usually occurs when user selects a different configuration file, e.g. "use configuration xyz", in the last reboot. This also could happen in the next boot when perpetual PoE is enabled and user changed fast PoE enable state and rebooted the switch without saving the configuration. The new configuration file has a different fast PoE enable setting from the one saved to the hardware. CLI command, "save configuration", will resolve the issue.
Severity
Warning
Message Text
Fast PoE configurations found in hardware at boot time do not match configuration file. Saving configuration will resolve this inconsistency.
